Vivek_tiwari
5 years agoConfiguration Error in Stratix 10 After programming .jic file
I Tried programming Stratix 10 FPGA kit with .jic file using jtag msel pins as MSEL[2:0] as 111 and it was programmed successfully configuration error led D3 was still glowing red after that i power ...
JohnT_Altera
5 years agoHi,
Could you provide me the SW1 DIP switch setting used? Have you try to set it to Fast AS mode (001)?
Have you try to program the sof file?
Vivek_tiwari
5 years agoHi,
I've tried both (001) AS FAST and (101) AS Normal as well.
I do not have any problem in programming .sof file
I am facing issues for .jic file.
