aamlb
5 years agoArria10SoC Development kit: Failing to burn the on board QSPI flash
I prepared a binary stream for burning to the QSPI flash: 128MB (MT25QU01GBBA8E12-0SIT), which installed on J11.
I followed the instructions on https://community.intel.com/t5/FPGA-Wiki/G...
YuanLi_S_Intel
5 years agoHi,
From the XML i dont see any problem, it seems like the setting during JIC file generation is appropriate. Another thing that i would like to check with you is on the IP side, during SFL IP initialization, have you selected 1024mb and also select as Active Serial configuration in Quartus?
Thank You
aamlb
5 years agoHi,
Please note that we are trying to boot the nios from the QSPI flash that installed on the EVB piggy card (J11).
- Does the controller should be configured to 'Active serial' also?
- There is also the following configuration:
- 1cs, 4B addressing
- Nios reset vector - (0x00f0_0000)
- added "PGM_ALLOW_MT25Q=ON" in quartus.ini local new file
Please advise if all the above as expected.
Thank you.
