16 years agoQuestion on factory configure file for MaxII in C3 or S3 dev. kit
I plan to reprogram the MaxII device in development kits for other usage. But I still hope it can be recovered to the factory configuration in the future. I find a file named M2_prod.pof file in the kit installation folder. No document explain it. Is that the factory configure file which I need?
That's correct.
Though there is updated file as version 1337, I think. You might want to double check at Altera web site. - Altera_Forum
--- Quote Start --- That's correct. Though there is updated file as version 1337, I think. You might want to double check at Altera web site. --- Quote End --- Thanks for your reply! I have searched the Altera web site, but can not find the updated file you mentioned. Could you give more info.?
