15 years ago
Question about PLL reconfig
I have been trying to reconfigure for couple of days now and i failed horribly. I am hoping you will shed some light to my doubts;
I have been following documentation for trying to reconfigure my PLL;
1. http://www.altera.com/literature/ug/ug_altpll_reconfig.pdf
2. http://www.altera.com/literature/hb/cyclone-iv/cyclone4-handbook.pdf
3. http://www.altera.com/literature/an/an507.pdf ( I understand that this is a tutorial for cyclone III device, but i figured the procedure will be the same because this is the only procedure i found that shows how to configure the PLL. All the other documents just gives reference info but no instructions.)
currently my PLL is configured as following;
inclock - 50 MHz
C0 - 7.5 MHz
C1 - 0.004 MHz
I created a ill reconfiguration module and connected the ports as shown in either of document 1(page 13 figure 9) and document 3(page 3 figure 2)
The All the inputs for the reconfiguration module is coming from my NIOS processor(write_param, read_param etc etc..)
Inclock for PLL reconfiguration module is 50 MHz
and reset comes from a push button KEY[0]
This is how the program flows
When the program starts, i generate two clock cycles C0 and C1 operating at 7.5 MHz and 0.004 MHz respectively
after about 10 sec, i want the clock frequency of C0 to change to 7.0 MHz and after another 10 second, i want my C1 clock frequency to change to 0.005 MHz.
Following is a snippet from my NIOS II code;
#include "includeme.h"
# include "piodriver.h"
int main()
	printf("Hello from Nios II!\n");
	 // This is the first 10 sec delay
	usleep(10000000);
	// Set counter type to C0
	output_data(COUNTER_TYPE_BASE, 0x4);
	// Set counter_param to bypass(4'b0100)
	output_data(COUNTER_PARAM_BASE, 0x4);
	// Set data_in to 1
	output_data(DATA_IN_BASE, 0x1);
	// Assert high for 10usec
	output_low(WRITE_PARAM_BASE);
	usleep(100);
	output_high(WRITE_PARAM_BASE);
	usleep(100);
	// Assuming busy is high at this point for 100ms
	// Busy will be alot less then this, but i used 100 just to be sure
	usleep(100000);
	//output_high(RECONFIG_BASE);
	//usleep(10);
	//output_low(RECONFIG_BASE);
	// Set counter type to N
	output_data(COUNTER_TYPE_BASE, 0);
	output_data(COUNTER_PARAM_BASE, 4);
	// Set data_in to 1
	output_data(DATA_IN_BASE, 50);
	usleep(100);
	usleep(100);
	usleep(100000);
	//usleep(10);
	usleep(100);
	// SET COUNTER_TYPE TO M
	output_data(COUNTER_TYPE_BASE, 1);
	// Set data_in to 1
	output_data(DATA_IN_BASE, 7);
	usleep(100);
	usleep(100000);
	  // Finally reconfigure the PLL
	usleep(100);
	printf("RECONFIG COMPLETE");
	return 0;
After doing this, my PLL doesn't get reconfigured. And after studying all three documents, i think i need help to solve this problem.
PLEASE any help would be greatly appreciated.
Pratish Karmacharya
