14 years agoQuestion about defining a Custom component in Sopc builder
Hi, I'm trying to build a custom component in Sopc builder to insert it in a Nios2 system...but whole procedure is not completely clear for me...!!! I don't understand if the registers to map on...
14 years agoin the document, NiosII and customIP are not comunicating by printf().
they are comunicating by the address. when you access to 0x000000 customIP gets those signals offsett address -> avs_address valid signal -> avs_write data -> avs_writedata when you get avs_write high, you can choose what to do with the address and data. in this example, what to do is store data of address 0 and return the value when address 0 is called. you can select what to do with the address number, this is the register mapping. you can communicate from NiosII into native hard ware language(HDL). try it anyway.
