quartus sythesize question
perhaps I didn't yet understand the example. I believe you'll get compilation errors in most cases.
Connecting an output port to a signal that is expected to drive an input will give a multiple driver error, because the signal is already driven. The reverse situation won't cause an error in the upper hierarchhy level, just leave an undriven signal. But in the lower hierarchy (module implementation) level, you can't drive the erroneously defined input without causing an error.
So you are apparently talking about a consistently designed module that is connected erroneously in the upper hierarchy. I think confusing in- and output ports is only one of many possible wrong connections and no particular case.
You'll want some kind of verification, e.g. with a simulator. It an easily mark undriven signals.
Frank
- SamPF1 year ago
Hi, FvM
First of all thanks for your reply, I'll give you an example to describe the problem I'm having.
You can see the Main_Seq module, PWRGD_a is the input, but I marked it as output. The final result b_EN will become high during simulation, which is also successful in quartus sythesize, but b_EN will not become high in the actual synthesis circuit.
Do you know how to verify this problem or use some settings in sythesize to avoid this problem?
module top(
output a_EN,
output b_EN,
input PWRGD_a,
input POWER,
input CLK_2M
);// Rst Control
wire Rst;
assign Rst = POWER ? 1'b1 : 1'b0;// sync signal
wire w_PWRGD_a;
sync sync_inst(
.clk(CLK_2M),
.Rst(Rst),
.iSync(PWRGD_a),
.oSync(w_PWRGD_a)
);Main_Seq main_seq_inst(
.clk(CLK_2M),
.Rst(Rst),
.a_EN(a_EN),
.b_EN(b_EN),
.PWRGD_a(w_PWRGD_a)
);endmodule
module sync(
input clk,
input Rst,
input iSync,
output oSync
);reg rSync;
reg [10:0] iSync_delay;
assign oSync = rSync;always @(posedge clk) begin
if(!Rst) begin
rSync <= 1'b0;
iSync_delay <= {11{1'b0}};
end
else begin
iSync_delay <= {iSync_delay[9:0], iSync};
end
endalways @(posedge clk)
begin
if(!Rst) begin
rSync <= 1'b0;
end
if(~|iSync_delay)
begin
rSync <= 1'b0;
end
if(&iSync_delay)
begin
rSync <= 1'b1;
end
endendmodule
module Main_Seq(
input clk,
input Rst,
output a_EN,
output b_EN,
output PWRGD_a
);reg a_EN_ff;
reg b_EN_ff;assign a_EN = a_EN_ff;
assign b_EN = b_EN_ff;always @(posedge clk) begin
if(!Rst) begin
a_EN_ff <= 0;
b_EN_ff <= 0;
end
else begin
a_EN_ff <= 1;
if(PWRGD_a) begin
b_EN_ff <= 1;
end
end
endendmodule
`timescale 1ns/1nsmodule tb_top;
reg clk;
parameter clk_period = 500;
initial begin
clk = 1'b0;
endwire a_EN;
wire b_EN;
reg PWRGD_a;always @(clk)
#(clk / 2.0) clk <= !clk;reg POWER;
initial begin
POWER = 1'b0;
PWRGD_a = 1'b0;
#(1000000) // 1ms
POWER = 1'b1;
endalways @(posedge a_EN & POWER) begin
PWRGD_a <= 1'b1;
endtop top_inst(
.a_EN(a_EN),
.b_EN(b_EN),
.PWRGD_a(PWRGD_a),
.POWER(POWER),
.CLK_2M(clk)
);endmodule
BR,SamPF
