Armando1989's avatar
Armando1989
2 years ago
Quartus simulation differs from board results
Hi there!
Recently purchased board from Aliexpress with EPM570T100C5 in it
Just programmed simple overflow accumulator as used in old fractional N synthesizer schemes. Mine with registered ouput for overflow so is one clock delayed.
module frac_acc(clk, reset, clk9600, prog, overflow, add);
input clk; //50MHz on board
input reset; //external reset pin
input [3:0] prog; //programing 4 bit add value
output reg [3:0] add; //adder result which feedbacks and adds to prog value each clk9600 cycle
output reg overflow; //overflow output
output clk9600; //9600 clock divide from 50MHz
reg [12:0] c=13'b1111111111111;
always @(posedge clk) begin
if (c>=5207)
c<=0;
else
c<=c+1;
end
assign clk9600 = (c <= (5208/2)-1)? 1'b1:
1'b0;
always @(posedge clk9600) begin
if(reset==1)
add<=0;
else
{overflow, add}=add+prog;
end
endmodule
Testbench:
`timescale 1ns/1ps
`define clk_period 20
module testbench;
reg clk;
reg reset;
reg [3:0] prog;
wire [3:0] add;
wire clk9600;
wire overflow;
frac_acc uut(.clk(clk), .reset(reset), .clk9600(clk9600), .prog(prog), .overflow(overflow), .add(add));
initial clk = 1'b1;
always #(`clk_period/2) clk = ~clk;
initial begin
reset=1;
#105000
reset=0;
#20;
prog = 4'b0000;
#10;
prog = 4'b0001;
#380000
reset=1;
#440000
reset=0;
end
endmodule
When simulated with tesbench result is as expected, for each 16 clk9600 cycles, overflow is set "PROG" value times. Ie: if PROG is prog = 4'b0001; then 1 time overflow is set each 16 clocks, as below image
 Problem arrives when i program into board... Instead of each 16 cicles; above is true just for half cicles, as if adder was 3 bits not 4.
So if i want actual chip to behave as per image, i need to set add[4:0] and prog[4..0] and reprogramm it, and so on
Anyone has experiences such behavior?
besides above, seems if input pins are not tied to ground it doesnt read as 0, so need tie to gnd for propper operation, no sure if pull down resistor or pin type is in order here.
Thanks!
  • clk9600 has most likely glitches in real hardware. Try to set in registered rather than combinational assignment.
  • FvM's avatar
    FvM
  • Armando1989's avatar
    Armando1989
    Hi FvM
    Yep, that did the trick
    if (c>=5207)
    c<=0;
    else
    c<=c+1;
    clk9600 <= (c <= (5208/2)-1)? 1'b1:
    1'b0;
    end
    The change added output through flip flop as per rtl netlist. so whatever glitch happened at logic it was stable after delayed clock. Its not first time i experience glitches, on this same design the carry propagation delay does a glitch, bigger chance when more adders in series, but after passing trough one clk delay it gives the room stabilize logic level so it is valid.
    Im quite new on quartus and didnt see the glitches on real scope at first, and since simulation appeared fine i was a little puzzled.
    I wish i know how to account for glitches at simulation level...
    Thanks!
  • We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum case, did not reach us as intended. As a result, we have a backlog of cases that we are currently working through.
    Please be assured that we are doing everything we can to resolve this as quickly as possible. This will take some time, and we appreciate your patience and understanding during this period of time. Your case will be attended by AE soonest possible.
    Thank you again for your patience and understanding, and we are committed to provide you with the best possible support.
  • Hi Armando1989,
    Seems like you have found the solution. Beyond this, is there any further support needed from our end ?
    Best Regards
    Hubert
  • Hi Armando1989,
    Is there any further support needed from our end ?
    Best Regards
    Hubert
  • As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
      Armando1989
      Hi HubertG
      This thread is already solved, thanks for your help.
      Br
