Armando1989
2 years agoQuartus simulation differs from board results
Hi there! Recently purchased board from Aliexpress with EPM570T100C5 in it Just programmed simple overflow accumulator as used in old fractional N synthesizer schemes. Mine with registered ouput fo...
- 2 years agoclk9600 has most likely glitches in real hardware. Try to set in registered rather than combinational assignment.
Armando1989
2 years agoHi FvM
Yep, that did the trick
always @(posedge clk) begin
if (c>=5207)
c<=0;
else
c<=c+1;
clk9600 <= (c <= (5208/2)-1)? 1'b1:
1'b0;
end
The change added output through flip flop as per rtl netlist. so whatever glitch happened at logic it was stable after delayed clock. Its not first time i experience glitches, on this same design the carry propagation delay does a glitch, bigger chance when more adders in series, but after passing trough one clk delay it gives the room stabilize logic level so it is valid.
Im quite new on quartus and didnt see the glitches on real scope at first, and since simulation appeared fine i was a little puzzled.
I wish i know how to account for glitches at simulation level...
Thanks!
