AEsqu
Contributor
6 years agoQuartus prime pro 19.1 always crashes on my project using arria 10 FPGA.
Quartus 13.1 on Stratix 3 FPGA has no problem with the same project (aside specific PLL/RAM/ROM,IO BUFFERS components).
See attached crash message.
Entry is a vqm from synplify pro 2019.09 (same for stratix 3 project).
- AEsqu
Contributor
Update: It is important to define the IO delay at the end of the sdc file,
because quartus does not know yet the clock definition when get_clocks * is used at the top.
I moved them at the bottom and I don't use get_clocks * anymore,
I define each pin with respective clock, using -add_delay when necessary (multiple clock domain per pin)..
