AEsqu
Contributor
6 years agoQuartus prime pro 19.1 always crashes on my project using arria 10 FPGA.
Quartus prime pro 19.1 always crashes on my project using arria 10 FPGA. Quartus 13.1 on Stratix 3 FPGA has no problem with the same project (aside specific PLL/RAM/ROM,IO BUFFERS components). See ...
AEsqu
Contributor
6 years agoUpdate: It is important to define the IO delay at the end of the sdc file,
because quartus does not know yet the clock definition when get_clocks * is used at the top.
I moved them at the bottom and I don't use get_clocks * anymore,
I define each pin with respective clock, using -add_delay when necessary (multiple clock domain per pin)..
