Quartus prime pro 19.1 always crashes on my project using arria 10 FPGA.
Hi, can you share your design that can duplicate this error?
What are the change made in the synthesis option that crashes with the second error?
- AEsqu6 years ago
Contributor
No, I cannot share it.
Below the options I changed, not sure which one affects the run:
set_global_assignment -name SYNTH_TIMING_DRIVEN_SYNTHESIS OFF
set_global_assignment -name FRACTAL_SYNTHESIS OFF
set_global_assignment -name MUX_RESTRUCTURE OFF
set_global_assignment -name INFER_RAMS_FROM_RAW_LOGIC OFF
set_global_assignment -name OPTIMIZATION_TECHNIQUE SPEED
set_global_assignment -name AUTO_ROM_RECOGNITION OFF
set_global_assignment -name AUTO_RAM_RECOGNITION OFF
set_global_assignment -name AUTO_DSP_RECOGNITION OFF
set_global_assignment -name AUTO_SHIFT_REGISTER_RECOGNITION OFF
set_global_assignment -name AUTO_CLOCK_ENABLE_RECOGNITION OFF
set_global_assignment -name OPTIMIZE_POWER_DURING_SYNTHESIS OFF
set_global_assignment -name HDL_MESSAGE_LEVEL LEVEL3
set_global_assignment -name BLOCK_DESIGN_NAMING QUARTUSII
set_global_assignment -name SYNTH_MESSAGE_LEVEL HIGH
set_global_assignment -name ALLOW_REGISTER_MERGING OFF
set_global_assignment -name ALLOW_REGISTER_DUPLICATION OFF
set_global_assignment -name BLOCK_RAM_TO_MLAB_CELL_CONVERSION OFF
set_global_assignment -name OPTIMIZE_IOC_REGISTER_PLACEMENT_FOR_TIMING OFF
set_global_assignment -name FINAL_PLACEMENT_OPTIMIZATION NEVER
set_global_assignment -name FITTER_AGGRESSIVE_ROUTABILITY_OPTIMIZATION NEVER
set_global_assignment -name QII_AUTO_PACKED_REGISTERS OFF
set_global_assignment -name AUTO_DELAY_CHAINS OFF
set_global_assignment -name FITTER_EFFORT "STANDARD FIT"
set_global_assignment -name ROUTER_LCELL_INSERTION_AND_LOGIC_DUPLICATION OFF
set_global_assignment -name ROUTER_REGISTER_DUPLICATION OFF
set_global_assignment -name DSP_BLOCK_BALANCING OFF
set_global_assignment -name ROUTER_CLOCKING_TOPOLOGY_ANALYSIS ON
- RichardT_altera6 years ago
I understand that you can not share your design due to confidential.
If possible, could you create a simplified design that can duplicate the same error? Our engineering team need a design in order to do any further debug.
