Quartus crashes after back annotation pins
I am using MaxV device with one pair of LVDS_E_3R. I can compile the design when I don't give any pin location assignment. However after the compile I do back annotation for pin and then when I hit compile, Quartus crashes during fitter run.
Error:
Internal Error: Sub-system: FYGR, File: /quartus/fitter/fygr/fygr_cdr_op_place.cpp, Line: 1882gid != DEV_ILLEGAL_GLOBAL_IDFitter pre-processing
Stack Trace:
I think the issue is with Pin Assignment. Attached is the QAR. It is a simple MUX.
Please advise.
- SreekumarR_G_Intel
Hello ,
Apologize for delay in response .
I get a chance to look at your design, but attached file not have any LVDS related IP is added. Can you please confirm the qar file attached ?
Also did you check pin out files what you mapped is correct ? Here is the link for your reference
Thank you ,
Sree
sorry missed to attached the line ,
https://www.intel.com/content/www/us/en/programmable/support/literature/lit-dp.html
Also here is the link for application notes LVDS_E_3R in MAX V
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an636.pdf
Thank you ,
regards,
Sree
- AKuma59
Hi! Sree,
The QAR is just a MUX structure. There in no LVDS related IP. I am trying to do a pin placement. The output of the MUX will drive the LVDS receiver chip connected to the CPLD. So two pins on bank 2 of the MAX V CPLD is set to LVDS_E_3R.
If I use Qii11.1 sp2, I don't see any compile error and the same QAR works just fine. But when I try to compile it with Qii18.1 prime (std or lite) , I get the Quartus crash.
i am not sure ...can you try to open the quartus with "Run as Administrator" , BY the way can I know the ram size of your machine ? also Can you uninstall and reinstall the quartus ?
Thank you,
Sree
- Disturbed_Pastry
I have the same problem as well even though I have added the LVDS IP, is there any fix to this?
