quartus (11.1sp2 and 15.1) not detecting de0 nano
You didn't post any picture.
What do you mean by "quartus can't find my altera boards"?
Are you using the device programmer tool and having it scan jtag for known devices?
Or what?
Are those boards known to be working?
yes, when I use the programmer tool, and click on hardware setup, I don't find usb blaster, that happened on both version of quartus
- ak6dn6 years ago
Did you click on 'Add Hardware' over on the right hand side in the Quartus Programmer?
You need to do that the first time, then Quartus will remember you have that device.
- leond956 years ago
yes i did but nothing happen
- ak6dn6 years ago
Need to check if you have a compatible USB Blaster device driver installed and configured.
Go to Control Panel / Device Manager and expand Universal Serial Bus controllers. You should have an entry for Altera USB-Blaster there. Right click on it and select Properties. They should show something similar to what I have done on my system. See below images.
