17 years agoptf files required
Hi all,
I have recently bought cyclone2 board with EP2C20F484C7 chip. The software I received does not contain any full featured or standard ep2c20*.ptf files. From where I can get them? Thank You3 Replies
What do you have? If you have the quartus projects, then a generation of the SOPC system and a compile of the Quartus project will give you the ptf and sof files you need.
Thank you for the reply.
I don't have quartus project for ep2c20. I have ep2c20.sof but no related *.ptf file. I could successfully run the program using C2_Starter_SD_Card_Audio.sof and C2_Starter_SD_Card_Audio.ptf but in that case output was seen only on the console not on the board. I tried several pairs of .sof and .ptf files to run the project but they are not working. what is the 'missing link' in my case? Thanks - Altera_Forum
The missing link is the Quartus project. You need the SOPC project to generate a ptf file.
