edoutthere
7 years agoProgramming the oscillators on the Cyclone V GT board
I have a Cyc V GI PCIE board. I can run the web based example as documentedin the user guide (ug_cvgt_fpga_dev_kit.pdf). Using this GUI, you can change the clock frequency of X3 and X4. These are co...
edoutthere
7 years agoRS, I did this and the install script worked. It installed the same content that the .zip does. Can you tell me where in the content that was installed the BSP is? Specifically, I need to see the code that runs on the FPGA when you unpack the board from the factory and run the kits "Clock Control" application. I dont kno for sure which FPGA image should be loaded when you run the Clock Control app.
The MAX5 is apparently being used as an I2C port for the SI clocks. Is there a definition for the registers in the MAX5?
BTW, the demos folder is empty
Ed
