Programming the oscillators on the Cyclone V GT board
Rs, The link you suggest is the home page for the board. On that home page, there are links to download the "installation kit". The windows version will not install because the installshield wizard encounters an error but gives no explanation. I got this to install on a windows 7 system once but this does not install on windows 10. I got the zip file tho, and there is no typical BSP in there. It has the MAX5 contents, a top-level signal def file (goldentop.v), and this project called board update portal which looks like a project to get the board running enough to program the flash?
There are these hsma, hsmb projects but they cannot be opened because qts sez there are errors in the qsf file. None of these projects have any interface to the MAX5 in the source.
Is there a BSP somewhere that I can bring up in qts that has example code for interfacing the MAX5 (and the clocks), or the source for what is in the FPGA when you unpack the kit and connect it up?
What is the purpose of this board if I have to write everything from scratch?
Ed
