11 years agoprogramming CFI flash on Arria V GX Starter Kit
I have a minimal Verilog program which I using successfully to program the Arria V FPGA on the dev kit. I light a few LEDs with the switches, nothing more. Now I want to program the flash device on t...
11 years agoHi,
Did you check the Arria V start kit user guide on the steps to program the CFI flash. Typically the user guide contains all the instruction for the flash programming. If you want to program the .pof into the CFI flash then you need to implement the PFL IP into the MAX V/MAX II device on the boards to access the CFI flash. You can check the PFL IP user guide for the details. Anyway before that it better to check the Arria V start kit user guide on the steps to program the CFI flash.
