12 years agoProgrammin the EPCS64 in the DE0-nano
I am having trouble programming the epcs64 configuration flash in the DE0-nano dev board. I have read an followed the instruction in the user manual for the board. I have successfully programmed the ...
12 years ago --- Quote Start --- Did you try programming the Spansion device directly using SPI? --- Quote End --- No, lack of a thing called time.... Plus, I just wanted to use the tools provided, not make up my own. --- Quote Start --- Not too drastic - it was almost certainly the fastest method to getting back to what you were supposed to be working on :) --- Quote End --- Yes, it was. After looking at the datasheets for the two devices, I thought the Spansion might have the Config register programmed where it can't be erased. The Altera device has no such register. I just didn't want to fool around any more! Thanks for you help on this, Dave. I may fool around with the Spansion device to figure it out more, but not on this project. Russ
