12 years agoProgrammin the EPCS64 in the DE0-nano
I am having trouble programming the epcs64 configuration flash in the DE0-nano dev board. I have read an followed the instruction in the user manual for the board. I have successfully programmed the ...
12 years ago --- Quote Start --- After getting nowhere --- Quote End --- Did you try programming the Spansion device directly using SPI? --- Quote Start --- I just replaced the Spansion chip with an Altera EPCS64... That fixed the problem. A little drastic, perhaps.:rolleyes: --- Quote End --- Not too drastic - it was almost certainly the fastest method to getting back to what you were supposed to be working on :) Cheers, Dave
