12 years agoProgrammin the EPCS64 in the DE0-nano
I am having trouble programming the epcs64 configuration flash in the DE0-nano dev board. I have read an followed the instruction in the user manual for the board. I have successfully programmed the ...
12 years agoAre you sure your DE0-nano is loaded with an EPCS64 device? I vaguely recall that some were shipped with Spansion devices, in which case, you would need to disable the ID check (its in the Advanced Options when you're generated a .jic programming file).
I have a DE0-nano with an EPCS64 device and it programs fine, so I can at least confirm that it works in principle. Cheers, Dave
