14 years agoProgram CPLD from Cyclone IV on BeMicro board
Hi all, This one's probably pretty basic, but I can't seem to find the answer anywhere... I want to program a MAX V CPLD _through_ the Cyclone IV on the BeMicro SDK board. On a ground-up ...
14 years agoHi Don,
--- Quote Start --- I want to program a MAX V CPLD _through_ the Cyclone IV on the BeMicro SDK board. On a ground-up design you would insert the CPLD in the JTAG chain with the FPGA, but I don't want to hack the BeMicro hardware, and don't see a way to do this without some creative soldering. (?) So what I want to try is hooking the CPLD JTAG lines to the FPGA's GPIO lines. PC <--JTAG--> FPGA <--GPIO--/--JTAG--> CPLD But it's unclear what to instantiate within the FPGA to make the connection... if I had access to the JTAG lines, it would be pretty simple... Can this be accomplished with the Virtual JTAG or other JTAG-related megafunction? Is the whole idea misguided? --- Quote End --- The Virtual JTAG interface can be used for the communication from the host component of this design, but unfortunately Quartus will not recognize this sequence of hardware as a JTAG chain, so you won't see your device in the programmer. I have used the Jam STAPL programmer to implement this type of interface. Basically you provide toggle callbacks for TCK/TMS/TDI/TDO. In this scheme you would have a Virtual JTAG or JTAG-to-Avalon-MM bridge component in your BeMicro and treat it like a GPIO board. You could buy a Terasic USB-Blaster for $50. Or if you are up for a challenge, you can buy the BEMICRO-PROTO board, an FTDI FT245R module (UM245R), solder that to a header on the BEMICRO-PROTO board, and then build your own USB-Blaster logic in the BeMicro (and the FT245 EEPROM) ... for probably around $50 plus your time. Cheers, Dave
