16 years agoProblems uploading flash memory -- part 2
Hi, I used the Nios II EDS sof2flash program in the Quartus II 9.1 License Edition to convert a sof file to flash format. I attempted to use the Board Update Portal and the Nios II EDS to...
13 years ago --- Quote Start --- The error comes from "nios2-elf-objcopy" not being found in your PATH. You'll need to add nios2-elf-objcopy's directory to your PATH. sof2flash uses nios2-elf-objcopy -O srec a.hexout a.flash to convert to flash. -- Konrad --- Quote End --- Hi Korand, I'm also facing same issue..Could you please tell me where i have to add the path of this nios2-elf-obj .. I'm getting error when i type the following command in nios2eds shell sof2flash --input= filename.sof --outpu=filename_hw.flash --offset=0x00020000 --pfl --optionbit=0x18000 --programmingmode=FPP and the error i'm getting is Jun 6, 2013 5:33:33 PM - (SEVERE) sof2flash: Error creating intermediate files, exiting ..i understud from your replies that i have to add path of nios2-elf ..but i didnt get where i have to add this path suppose i have nios-elf-objcopy in " D:\altera\nios2eds\bin\gnu\H-i686-mingw32\bin " in this direc..where i have to add the path?? Pls help me friends
