16 years agoProblems uploading flash memory -- part 2
Hi, I used the Nios II EDS sof2flash program in the Quartus II 9.1 License Edition to convert a sof file to flash format. I attempted to use the Board Update Portal and the Nios II EDS to...
15 years agoPS: Tried these java's by adding them to head of PATH & still get java errors from sof2flash:
altera/10.1/quartus/linux64/jre64/bin/java altera/10.1/quartus/linux64/jre/bin/java altera/10.1/quartus/linux/jre/bin/java >java -version java version "1.6.0_14" Java(TM) SE Runtime Environment (build 1.6.0_14-b08) Java HotSpot(TM) Server VM (build 14.0-b16, mixed mode) >java -version java version "1.6.0_14" Java(TM) SE Runtime Environment (build 1.6.0_14-b08) Java HotSpot(TM) 64-Bit Server VM (build 14.0-b16, mixed mode)
