16 years agoProblems uploading flash memory -- part 2
Hi, I used the Nios II EDS sof2flash program in the Quartus II 9.1 License Edition to convert a sof file to flash format. I attempted to use the Board Update Portal and the Nios II EDS to...
15 years agoHi Jake,
Since it was brought up in this thread.... I'm also getting the sof2flash java problems on 64b SUSE linux (& 10.1). I'm probably just missing a doc on how to setup my env, but I've been hacking at it & would appreciate any pointers. Here's my env setup: setenv ALTERA_ROOT /home/altera/10.1 setenv SOPC_KIT_NIOS2 ${ALTERA_ROOT}/nios2eds setenv _QUARTUS_ROOT ${ALTERA_ROOT}/nios2eds/../quartus setenv QUARTUS_ROOTDIR ${ALTERA_ROOT}/quartus setenv _NIOS2EDS_ROOT ${ALTERA_ROOT}/nios2eds/ setenv PATH ${PATH}:${ALTERA_ROOT}/nios2eds/bin/gnu/H-i686-mingw32/bin:${ALTERA_ROOT}/nios2eds/sdk2/bin:${ALTERA_ROOT}/nios2eds/bin:${ALTERA_ROOT}/quartus/bin:${ALTERA_ROOT}/quartus/sopc_builder/bin And that seems good enough for nios2-configure-sof and nios2-flash-programmer to run. Unfortunately, I get this for sof2flash: >sof2flash --pfl --optionbit=0x18000 --programmingmode=FPP --input=tpe.sof --output=tpe_hw.flash --offset=0x640000 ; Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Version 10.1 Build 153 11/29/2010 SJ Full Version Info: Copyright (C) 1991-2010 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, Altera MegaCore Function License Info: Agreement, or other applicable license agreement, including, Info: without limitation, that your use is for the sole purpose of Info: programming logic devices manufactured by Altera and sold by Info: Altera or its authorized distributors. Please refer to the Info: applicable agreement for further details. Info: Processing started: Fri Mar 18 09:27:35 2011 Info: Command: quartus_cpf -c tpe_hw.cof Info: Memory Map File tpe_hw.map contains memory usage information for file tpe_hw.pof Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Peak virtual memory: 327 megabytes Info: Processing ended: Fri Mar 18 09:27:50 2011 Info: Elapsed time: 00:00:15 Info: Total CPU time (on all processors): 00:00:10 Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Version 10.1 Build 153 11/29/2010 SJ Full Version Info: Copyright (C) 1991-2010 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, Altera MegaCore Function License Info: Agreement, or other applicable license agreement, including, Info: without limitation, that your use is for the sole purpose of Info: programming logic devices manufactured by Altera and sold by Info: Altera or its authorized distributors. Please refer to the Info: applicable agreement for further details. Info: Processing started: Fri Mar 18 09:27:50 2011 Info: Command: quartus_cpf -c tpe_hw.pof tpe_hw.hexout Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Peak virtual memory: 339 megabytes Info: Processing ended: Fri Mar 18 09:28:22 2011 Info: Elapsed time: 00:00:32 Info: Total CPU time (on all processors): 00:00:28 java.lang.NullPointerException at com.altera.utilities.Launcher.read(Launcher.java:307) at com.altera.utilities.Launcher.read(Launcher.java:362) at com.altera.sof2flash.PFLFlashGenerator.convertHexToSREC(PFLFlashGenerator.java:239) at com.altera.sof2flash.PFLFlashGenerator.pflgen(PFLFlashGenerator.java:37) at com.altera.sof2flash.Sof2flash.<init>(Sof2flash.java:122) at com.altera.sof2flash.Sof2flash.main(Sof2flash.java:77) Mar 18, 2011 9:28:22 AM - (SEVERE) sof2flash: Error creating intermediate files, exiting -------- Some additional info in case it helps: > uname -a Linux sprite 2.6.32.12-0.7-default# 1 SMP 2010-05-20 11:14:20 +0200 x86_64 x86_64 x86_64 GNU/Linux > java -version java version "1.6.0" Java(TM) SE Runtime Environment (build pxa6460sr7-20091215_02(SR7)) IBM J9 VM (build 2.4, JRE 1.6.0 IBM J9 2.4 Linux amd64-64 jvmxa6460sr7-20091214_49398 (JIT enabled, AOT enabled) J9VM - 20091214_049398 JIT - r9_20091123_13891 GC - 20091111_AA) JCL - 20091202_01 So, it made .pof, .map, and .hexout files before it died. -Brian
