16 years agoProblems uploading flash memory -- part 2
Hi, I used the Nios II EDS sof2flash program in the Quartus II 9.1 License Edition to convert a sof file to flash format. I attempted to use the Board Update Portal and the Nios II EDS to...
16 years agoIf you have Quartus II 9.1 SP1 installed, you no longer need to program the device first and then read it back as .flash file.
To convert a .sof to a .flash file, use the following command in Quartus II 9.1 SP1: sof2flash --pfl --optionbit=<option bit address offset> --input=<your SOF.sof> --output=<output.flash> --offset=<desired image offset> For example, to create a .flash file for the Stratix IV GX Development kit sof2flash --input=<yourfile>.sof --output=<yourfile>.flash --offset=0xC20000 --pfl --optionbit=0x18000 Output: • A FLASH file containing the SOF data. • A FLASH file containing single image option bits for the PFL located at the address you specified with the --optionbit=<offset> option. You should only program the *.map.flash file to flash if either of the following applies: 1. You don't have existing option bits at the appropriate location in flash 2. You only need to configure a single image. Note that most of the Altera development board should already have the option bits, so there is no need to program the *.map.flash
