16 years agoProblems uploading flash memory -- part 2
Hi, I used the Nios II EDS sof2flash program in the Quartus II 9.1 License Edition to convert a sof file to flash format. I attempted to use the Board Update Portal and the Nios II EDS to...
16 years agoMSEL is a FPGA pin which determine if you can use compress mode or not
As I mentioned, the PFL in max2 on this board only supports loading data, and PFL in FPGA on this board only supports write Flash function. It is just a matter of what external chip can do and what already implemented in the max2. If you change max2 PFL, sure you can write into Flash. So AN386 is still correct. Yes, you need to set start or block, otherwise, auto will set start/end (most likely, start from 0x00 and the next page to be right after the previous page)
