16 years agoProblems uploading flash memory -- part 2
Hi, I used the Nios II EDS sof2flash program in the Quartus II 9.1 License Edition to convert a sof file to flash format. I attempted to use the Board Update Portal and the Nios II EDS to...
16 years agoI have the same problem with the StratixIV GX Development Board and QuartusII 9.1. While trying to do the board recovery process, I discovered that there is an errata in the file "altera\91\kits\stratixIVGX_4sgx230_fpga\factory_recovery\build_factory_source\build_factory_readme.txt". It says:
Problem Description: The release of Nios II EDS 9.1 tool "sof2flash" does not include support for Stratix IV GX . Work-around: ..... The described the procedure, but the 9.1.0 kit that I have does not have the required file "s4gx230_pfl_programming.sof" required to do parallel programming. I submitted an SR and the response confirmed that this is a bug in 9.1. I have updated my SR to request the "s4gx230_pfl_programming.sof" file. With respect to the .flash file size, the .flash file is in the SREC format which has a text based representation of the binary image. My experience is that this will be over twice as large as the actual binary image.
