DGiar
7 years agoProblems in programming the EPCQ using the AS (Active Serial) configuration.
Hi, I’m using the Cyclone V E FPGA Development Kit and I’m trying to program the EPCQ using the AS (Active Serial) configuration. I did the following steps: - I correctly configured the MSEL pins ...
Nooraini_Y_Intel
7 years agoHi Diego,
Did you try to erase the MAX V contents first? Before programming the .jic file, first I would erase the MAX V contents. Then ensure the MSEL pins (dip SW1) is set for AS mode. When program the .jic file, I can see the programmer can successfully detect the EPCQ256 ID (0x19) and continue to perform erase and program operation.
Nooraini
