DGiar
7 years agoProblems in programming the EPCQ using the AS (Active Serial) configuration.
Hi, I’m using the Cyclone V E FPGA Development Kit and I’m trying to program the EPCQ using the AS (Active Serial) configuration. I did the following steps: - I correctly configured the MSEL pins ...
Nooraini_Y_Intel
7 years agoHi DGiar,
Did you set the MSEL 4,2,1,0 pins to AS mode? At dip SW1 you are require to set the MSEL pins according to the correct configuration scheme. Thus you need to set the SW1 either to 1011 or 1010. You can refer to the attached screen shot. We have a Cyclone V E dev kit that I can program the .jic file successfully.
Nooraini
