DGiar
7 years agoProblems in programming the EPCQ using the AS (Active Serial) configuration.
Hi, I’m using the Cyclone V E FPGA Development Kit and I’m trying to program the EPCQ using the AS (Active Serial) configuration. I did the following steps: - I correctly configured the MSEL pins ...
DGiar
7 years agoHi Nooraini,
thank you for your answer.
I tried to do what you said and I obtained the following:
- With 24 MHz clock the progress bar stops at 44%
- With 12 MHz clock the progress bar stops at 58%
- With 6 MHz, 3 MHz and 2 MHz (and so on) clocks the progress bar stops at 73%.
Sorry for asking you again, but do you have any tips for solving this?
Thank you in advance.
Regards.
