DGiar
7 years agoProblems in programming the EPCQ using the AS (Active Serial) configuration.
Hi, I’m using the Cyclone V E FPGA Development Kit and I’m trying to program the EPCQ using the AS (Active Serial) configuration. I did the following steps: - I correctly configured the MSEL pins ...
Nooraini_Y_Intel
7 years agoHi DGiar,
Since you are using USB Blaster II cable, can you try to reduce the USB Blaster II TCK value to either 16Mhz or lower? By default, the frequency for the USB-Blaster II download cable is 24MHz. For the steps to change the USB Blaster II TCK value, please refer to the following KDB link:
Once you have change the TCK value, please try to program the .jic file if this help to fix the issue.
Nooraini
