Problems in programming the EPCQ using the AS (Active Serial) configuration.
Hi, thank you for your answer.
The error message is the following:
“Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly.”
The point is that I can program the FPGA with the .sof file correctly (see “Screen1”), while I cannot program the EPCQ with the .jic file (see “Screen2.png”): I noticed that in the first case the Device Name is 5CEFA7F31, while in the second case the Device Name is only 5CEFA7 and I cannot change it.
Also, when I generate the .jic file I cannot select the 5CEFA7F31 (see “Screen3.png”).
Hope that this help, thank you in advance.
