DGiar
7 years agoProblems in programming the EPCQ using the AS (Active Serial) configuration.
Hi, I’m using the Cyclone V E FPGA Development Kit and I’m trying to program the EPCQ using the AS (Active Serial) configuration. I did the following steps: - I correctly configured the MSEL pins ...
Nooraini_Y_Intel
7 years agoHi DGiar,
What is the error message when the Quartus programmer failed to program the EPCQ256 (progress bar failed at 44%)? In the Quartus message log, you should be able to see the error message. You can perform auto-detect operation with the Quartus programmer to detect if the JTAG chain contain a single device (Cyclone V) or multiple devices (Cyclone V + MAX V). If the Quartus programmer only detect Cyclone V then the MAX V should already bypassed.
Nooraini
