14 years agoProblem with tPad VIP Camera demonstrations
Hello, I have the tPad DE2-115 and I try to use the VIP Camera demonstration. After compilation of the hardware with the only changement in the reset of the nios (sram instead of flash). I prog...
14 years agoIf someone has the same problem. The solution is to change the section from the sdram to the sram in the bsp editor.
