14 years ago
Problem with Quartus II 11.0 Programmer detecting Altera Cyclone II DE2 Dev Kit
After tools -> programmer the Programmer these show up like in the attached image.
For hardware type, there is none other then ethernet blaster; and auto detect didn't work.
Basically the Dev Kit does not want to be recognised by Quartus II v11.0
If any, these are observed and done:
  • Board is powered on
  • Tested when switch is at RUN and PROG
  • Restarted program
  • Restarted computer
  • USB is connected from USB BLASTERt port of the board to the computer
And the USB Blaster driver had been searched and located for instalallation and installed from this path:
C:\altera\11.0\quartus\drivers
Only seemed to be able to installed that way, and when earlier tried these methods to install but they didn't work:
Just to note, I am using Intel Core i3 Windows 7 32-bit
Any help will do.
Thank you!
    Dear ,
    Go to device manager see if you can find USB Blaster II and update them
    If not Install USB Blaster II drivers and try it out.
