14 years agoProblem with Quartus II 11.0 Programmer detecting Altera Cyclone II DE2 Dev Kit
After tools -> programmer the Programmer these show up like in the attached image. For hardware type, there is none other then ethernet blaster; and auto detect didn't work. Basically the ...
14 years agoevery ime i compile my program this error appear idon't know why
Error: Port "r" does not exist in primitive "dff" of instance "U4" this is my program library ieee; use ieee.std_logic_1164.all; entity usr is port(clk,srsi,slsi:in bit; s :in bit_vector(1 downto 0); I: in bit_vector(3 downto 0); A: out bit_vector(3 downto 0)); end; architecture universal_shift_register of usr is component mux is port(a0,a1,a2,a3:in bit; S: in bit_vector (1 downto 0); f: out bit ); end component; component dff is port (clk,d:in bit; r: out bit ); end component ; signal d0:bit; signal d1:bit; signal d2:bit; signal d3:bit; signal da0:bit; signal da1:bit; signal da2:bit; signal da3:bit; begin U0:mux port map(da0,da1,slsi,i(0),s,d0); U1:mux port map (da1,da2,da0,i(1),s,d1); U2:mux port map(da2,da3,da1,i(2),s,d2); U3:mux port map(da3,srsi,da2,i(3),s,d3); U4:dff port map(clk,d0,da0); U5:dff port map(clk,d1,da1); U6:dff port map(clk,d2,da2); U7:dff port map(clk,d3,da3); A(3)<=da3; A(2)<=da2; A(1)<=da1; A(0)<=da0; end; library ieee; use ieee.std_logic_1164.all; entity mux is port(a0,a1,a2,a3:in bit; S: in bit_vector (1 downto 0); f: out bit ); end; architecture mux4_1 of mux is begin process (S) begin case S is when "00" => f <= a0; when "01" => f <= a1; when "10" => f <= a2; when "11" => f <= a3; end case; end process; end; library ieee; use ieee.std_logic_1164.all; entity dff is port (clk,d:in bit; r: out bit ); end; architecture ff of dff is begin process (clk,d) begin if(clk'event and clk<= '1')then r<=d; end if; end process; end; i want your help
