SImen
6 years agoProblem with GPIO port altera board
Hello all, I'm using the altera board. I'm implementing a new system based on the Computer system project provided with the board. I added new PIO modules in Qsys and performed generation and instan...
EBERLAZARE_I_Intel
6 years agoHi,
May I know which Quartus Version you are using? Also, which board are you currently working on?
I recommend that you read our user guide on the PIO IP:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf#page=297
Regards.
- SImen6 years ago
Hi , thank you so much for your reply
I finally found that the problem was with licensing of some FPGA IP cores , a time limited sof file was generated that caused the problem
since i was downloading the old sof programming file
Is there a way to get an unlimited version with the quartus prime lite version
regards
- EBERLAZARE_I_Intel6 years ago
Our Quartus Prime Lite Version is available as a free download with no license file required.
Regards.
