problem with bsp generation after qsys modification
i have a problem with bsp generation after qsys modification;
During conpilation i have this error :
SEVERE CPU "nios2_qsys_0" reset memory "avl_bridge_slave_full_mm" has no matching memory region
how can i match the memory region? there are no error after qsys generation...
job is on cyclone V, quartus prime 17.1
Thank you in advance for your answers....
- MEIYAN_L_Intel
I would like to know do you modified the BSP in Qsys system?
May I know what have you change and can you list down the flow?
Also, can you attached the full design here for further investigate?
- DTebo2
hi,
Thank you for your answer. We did not modify the BSP (the native BSP) only some interface of the qsys core.
Please see attachements
- MEIYAN_L_Intel
In the Qsys system, I saw the Nios II processor with reset vector memory is assign as "avl_bridge_slave_full_mm".
Based on the error message, can you try to connect the avl_bridge_slave_full_mm to an on-chip RAM?
