14 years agoProblem with Avalon Slave Template
Hi, when I try to open the altera avalon slave template in the component editor tool of sopc builder, two message windows (Fig.1 attached) appear, if I click on "Remove TCL Callback"...then I can ...
14 years agoYes you can do that. Those are depreciated APIs so they should still work. Whatever version of the tools you use when you make that change I recommend putting that "package require -exact sopc <version>" at the top which will make sure the component will work moving forward using the same API version.
