MMinu3
6 years agoProblem erasing EPCQ flash memory on INTEL Cyclone evaluation board with Generic Serial Flash Interface Intel running on NIOS II
As mentioned above, I'm not able to erase Flash Memory (neither sectors, sub-sectors, or bulk) using the Generic Serial Flash Interface Intel running on NIOS II: only with "Quartus programmer" I can....
JohnT_Altera
6 years agoHi MM,
From my understanding, after 160ms, you are observing the Status values is 0x0. So if you performed a read, what will happen? It should be 0xff right?
