MMinu3
6 years agoProblem erasing EPCQ flash memory on INTEL Cyclone evaluation board with Generic Serial Flash Interface Intel running on NIOS II
As mentioned above, I'm not able to erase Flash Memory (neither sectors, sub-sectors, or bulk) using the Generic Serial Flash Interface Intel running on NIOS II: only with "Quartus programmer" I can....
MMinu3
6 years agoHi, if you take a look to the attached images, you can see that the erase operation take about 160ms and the Status values is always 0x03, except the last one whose value is "0"... as expected.
MM
