Mikel
7 years agoProblem configuring Cyclone 10 LP in Passive Serial mode
I have designed a system which uses a Max 10 (10M08SCU169I7G) with a Micron flash (MT28EW128ABA1HPN) connected to it, to configure a Cyclone 10 LP (10CL040YF484I7G) in Passive Serial mode. I am usin...
ShafiqY_Intel
7 years agoHi Mikel,
Here some option you can try:
- In MAX 10 design, Ensure that the unused pins are reserved as input tri-stated. Go to Assignment → Device → Device & pin options → Unused Pins.
- Is your design use ratio input clk to Dclk =2? if not, maybe you can change it to 1.
- For "Use advance read mode: " option, can you change it to "normal" instead of "32 Bytes Page Mode (MT28EW)"?
- when you want to program the design into CFI flash, Make sure you tick only on "your design". do not tick the bit_option. refer image below for more details:
If your issue have not improve, please let me know.
