sn681
3 years agoPower up the device(CYCLONE 5) in temperature under zero
we are using in our board the device CYCLONE 5 - 5CSEBA5U23, when we are trying to power up the device in temperature under zero( -5 cel), we are getting the " altera_load" failed with error code -...
sn681
3 years agoHi Aiman,
-We check all power rails there is no change when power up below 0cel.
-We measure the voltage during the power up, the are setting ok.
-The signal "conf_done" stays low.
-There are no different components between the boards, the 10 devices using the same board.
