sn681
3 years agoPower up the device(CYCLONE 5) in temperature under zero
we are using in our board the device CYCLONE 5 - 5CSEBA5U23, when we are trying to power up the device in temperature under zero( -5 cel), we are getting the " altera_load" failed with error code -...
NurAiman_M_Intel
3 years agoHi,
Apologize for the delay in response.
Can you check:
- Power up status such as
- power rails all power up correctly
- Measure the voltage during the power up
- Also, different component on the board can also effect the power up
- And, is there any changes when power up between those 10 devices? Are the 10 devices using the same board or different board?
Aiman
