Power up the device(CYCLONE 5) in temperature under zero
we are using in our board the device CYCLONE 5 - 5CSEBA5U23,
when we are trying to power up the device in temperature under zero( -5 cel),
we are getting the " altera_load" failed with error code -2" and the "conf_done" stays low.
If the board is power up in a positive temperature , and we are cooling the board, the device working fine.
We check all signals control , the are setting ok.
- NurAiman_M_Intel
Have you follow our userguide when configuring and power up the FPGA?
Aiman
- sn681
Hi Aiman,
We designed our board according to Intel's recommendation.
The device works great in all temperatures, but when we trying to turn it on at temperatures below zero
we are getting the " altera_load" failed with error code -2".
Is there anything we can try to resolve this ?
- NurAiman_M_Intel
Thank you for the update. Can you provide us the screenshot of the failure/error code?
Aiman
- NurAiman_M_Intel
Also, please provide the full device OPN.
- NurAiman_M_Intel
If you ae using commercial device, the operating junction temperature should be between 0 to 85C.
- sn681
- NurAiman_M_Intel
-How many devices show the same failure when power up using below 0cel?
-Please share the top marking for the failing devices.
Aiman
- sn681
Hi Aiman,
- We tested 10 devices and 8 of them showed an failure when power up below 0cel.
-You want me to share the top marking of the CYCLONE V - 5CSEBA5U23?
- sn681
Hi Aiman,
Is there any update?
- sn681
