14 years agoPower monitor from the Arria II GX kit doesn't see USB blaster?
Sirs, I have got USB blaster working on Windows 7 (see my previous post (http://alteraforum.com/forum/showthread.php?t=35765)). Programmer works well, I was able to auto-detect and program my d...
14 years ago --- Quote Start --- Ran jtagconfig -n in NIOS command shell. Here's what I got... Altera Nios2 Command Shell [GCC 4] Version 11.1, Build 173 --- Quote End --- Note how this is version 11.1 --- Quote Start --- ... then I tried to navigate to the appropriate install directory, ran BoardTestSystem.exe, and here's what I got in a pop up ... Quartus or Quartus Programmer's Active version is not 10.1. Please set 10.1 to be the active Programmer version --- Quote End --- and this wants to use 10.1. Do you have 10.1 installed? If you do, then start the Quartus GUI for 10.1, and then start the board test system GUI. Starting Quartus first should set the paths correctly. If that does not work, start the NIOS IDE shell for 10.1, and then from that shell run the executable for the board test system GUI. Cheers, Dave
