13 years agoPossible low frequency (<400kHz) capability on the THDB_ADA board?
I know there is a way to desolder a transformer on the DAC part of the THDB_ADA board, to achieve low frequency single ended output. Can a similar thing be done to the ADC circuitry in order to...
13 years agoI suggest to refer to the AD9248 datasheet for possible solutions. There's an option to use the ADC in single ended configuration, although it involves a certain performance degradation. It would need an additional voltage divider bypassing the +input to Vcc/2 and a large input coupling capacitor, e.g. 10 µF ceramics.
My personal favourite is a DC capable fully differential amplifier as single ended to differential converter, as used in the AD9248 evaluation board, the schematic is also included in the datasheet.
