14 years agoPIO to Memory to PCIe on Arria II GX
Hello, I'm sorry to ask you such simple things, but I'm nearly running mad. My Problem is: I want to check the data of a 32 bit wide general bus. This bus has a clock of 50 MHz. My intention is...
14 years agoI'm running mad with this!
OK, I created a bdf-File where I connected the PIO Inputs to a Pin PIOIn[31..0]. Then I created a node in Pin-Planner with the same Name and in the "Set Up Top-Level-Design File" I declared them as Input. Then I typed in the Pins on each Port of the PIO (PIOIn[0] to PIOIn[31]). Back in the bdf-File there was a Box which shows me the Pins and beyond them the Signal I want to use (3.3-V LVTTL). But the Assignment-Editor shows the PIOIns always as unknown. Must I create a Top-Level-Design File? I have tried this but it always destroys the Design because there seem to be some pins that are assigned to several Inputs/Outputs. Is there anybody out there who can give me a dumba*s-Manual. I already tried to use the Help and read in the Altera Manual but all it says to me is: "The Pin Planner is a thing to plan your pins." Please HELP!!
