SP1's avatar
SP1
6 years ago
pin assignments to GPIO of Cyclone II
Dear Sir/Ma'am got the starter kit of Cyclone II :
I am facing a problem regarding pin assignments. I tried to assign an on-board switch to an on-board LED.
Similarly, I assigned a switch to external pins: GPIO 0 or GPIO 1 plug, but nothing is working ---means I cannot assign any IO's to external peripherals through these plugs.
INTERNAL : Switch ------- Internal ------ LED works fine LED lights if switch on and vice - versa
EXTERNAL : Switch ------- Internal -------LED doesn't work (Switch is connected to 3.3 Vdc from the board)
3.3V ____/ ________............._____LED.
PLEASE can you help me. Can not find any reference to this problem in manual ---- Pin assignment as per the instruction.
With kind regards,
Sayali Pawar
Electronics Engineer
MIT, Australia
