15 years agoPin Assignments -- less tedious way?
I have a Cyclone III 3c120 development board and am using the terASIC Data Conversion Card on the HSMC. Is there any better way of getting the pin assignments than doing them manually one by on...
15 years ago --- Quote Start --- I exported the assignments from "Assignment Editor" for an example project, and it looks like it's just a Tcl script. I looked through your attached files, and I imagine that at some point you had to reference the schematic and enter each pin manually. Is that correct? --- Quote End --- The way I generate the files is to either start with a schematic, or start with an example design and export the pin assignments. The Altera constraints are waste of typing, so in constraints.tcl I use a short-hand "keyword=value" notation for the pin assignments and constraints, and then use Tcl loops to convert the keywords and values to Altera-specific Tcl constraints. --- Quote Start --- I know it's a one-time ordeal, but I was wondering if these assignments already existed. Particularly, it's confusing to go between the two schematics: the schematic for the HSMC card, and then the schematic for the development board. --- Quote End --- I always use the same design pin names (entity definition) for the top-level file, with all pins defined (regardless of whether the design uses them or not). For example, the HSMC connector would be generically named hsma_lvds_a etc. What those pins connect to is design-dependent and happens inside the top-level design file, i.e., hsma_lvds_a will get renamed or aliased to make the code easier to read. Try not to rename top-level pins to match an HDL design, as then you have to have a constraints file that depends on your design. Keep the top-level entity pin names the same, and simply connect them to new names at the top-level file in a project. Cheers, Dave
